주요 콘텐츠로 건너뛰기
Google's 2nd-generation Pixel XL sports a 6-inch P-OLED display with rounded corners. Available in 64 and 128 GB storage configurations, and in two colors: Just Black and Black & White. Released October 19, 2017.
72 질문 전체 보기
4G Randomly disconnecting after screen and charging port replacement
Hey, after replacing the screen and charging port on my Pixel 2 XL my cellular data has kept disconnecting. Did i do something wrong? Do i need to open to phone again to fix or buy new parts? Here is a screenshot from the status bar when it disconnects
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
You might want to open the phone again and try reconnecting the connector for the new charging port. Also try rebooting it a few times. The Turn off and back on thing is very old fashion but sometimes it works! Best of luck!!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had a similar issue with my Galaxy S4 a few years back, when I first started getting interested in repairs. I had accidentally snapped the head off the antenna so it obviously wasn’t connected. I only realized it when my signal was crap and I had to buy a new antenna. It may also be due to the charging port connector as Ian Shalongo said.
Before you go ripping your phone apart though, you should try a few things…
Try rebooting the phone.
Check for any updates. Many Pixel 2 owners had signal problems that needed an update to be fixed.
Try basic trouble shooting steps like popping the SIM out and back in, resetting network settings, etc. There is a really good guide for
https://thedroidguy.com/2019/03/how-to-f...
Good luck and God Bless
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I have tried the basic steps like taking out the sim and rebooting it multiple times and even done a factory reset on the device without any luck. I think im just going to buy a new display adhesive and rip the phone open to see what i did wrong.
Did you reconnect both ends of the antenna wire along the right side of the phone?
댓글 달기
귀하의 답변을 추가하세요
Mico Hautaluoma 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 64
