주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Hover-1 Horizon is a self-balancing electric scooter that has built in Bluetooth speakers, LED headlights and a rechargeable battery. Model: HY-H2L-Hover-1 Horizon
Hall Sensor on HOVER-1 registers faulty. How do I repair that?
After successfully calibrating my hoverboard I turn it off and then back on and climb in the seat of “the buggy”, the HOVER-1 seat attachment, I try to move forward by pushing gently down on both controls evenly. I start to move but suddenly the RIGHT side “gives in” and there is no response from that side. There seems to be zero power going to that wheel. It will work again for a moment after turning off/on but it always stops operating. When it goes out there is no resistance and does not spring back like it should. So running the diagnostic test on the HOVER-1 app it shows the screen labeled “A”.
“HALL SENSOR Fault“
So my question is '''what can be done about this? Does this typically mean I will need replacement parts or does it mean a lose wire?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Did you ever find out the answer? I have the same exact issue right now and haven't found an answer!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kyle johnson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 39
전체 시간: 1,486
