주요 콘텐츠로 건너뛰기
Can I cut charger and connect wires to rechargeable speaker wires
I broke my mirco use charging port for my speaker and i don’t have cash to fix it. Would is be possible to cut my phone charger and the connect those wires
charger:Blue Red
Speaker:Black Red
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Are those wires (Black and Red) connected to the speaker itself? If it does, you snapped the wrong wires. Solder them back to the board. You could solder a connection but the speaker won’t be portable anymore (since the charger is soldered into the board of the speaker). Solder the Positive wire of the charger to the positive terminal (the place where the micro usb connector is attached) and negative to the negative terminal.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes just match color code for each jack
Most jack are the same colors just rearanged.as jacks progress so does the number of paired wires.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sounds to me like ur dealing with a short
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
rbo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 2,898
