주요 콘텐츠로 건너뛰기
Why doesn't it power on
My laptop stopped showing life signs( no lights,no bootup) then i opened it and removed the power button and plugged in the ac cord and it showed lights…but i couldn’t turn it on so i plugged the power button and it didn’t show any light more…help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
You wrote "power button". Did you mean "battery" ? If that is the case, how long did you wait, after plugging in the battery charger, before attempting to turn it on.
If the battery is completely flat ( no charge) there will be NO residual power on the motherboard. In this case it may take several seconds before it will switch on. So plug in charger, lights come on, wait about 10 seconds or so and then try to switch on the laptop.
I clearly meant the power buttom
The battery is fine the...if i plug the power button in the laptop doesn't show life...if i unplug it, it shows the charging light but then i can't turn it on because the power button is unplugged
댓글 달기
답변 1개
가장 유용한 답변
Power button defective.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
It works! But it makes the lights from my laptop dissappear...does anyone now how to turn a laptop on with the keyboard or something
댓글 달기
귀하의 답변을 추가하세요
Matteo Mireuta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 111
