주요 콘텐츠로 건너뛰기
Samsung Galaxy S6 Edge+는 Galaxy S6 Edge 스마트폰의 커진 버전입니다.
99 질문 전체 보기
help me to fix my phone pls
Hello ..
i have samsung s6 edge + ( sm-g928f ) i love this device and been using it since 3 years ..
yesterday i wonted to root it but couldn't so i road about that and i had to turn off the OEM
after root was every thing good until i enable OEM and restart the device ..
it stak in boot screen with red line ( Binary Blocked by FRP Lock on )
i didn't knew what i should do so i try every thing i know to backup the file i couldn't ,,
finally i fleshed a stocked ROM from Sammobiel and plug it in the charging cable and installed every thing i need from store ..
after that Evey time i unplug the phone from phone 10 sec freeze and turn off so i flashed second time another ROM and third from sammobile
if the phone was unplug and i turn it on when i get the phone menu restart immediately
i tried safe mode the same
what i the problem is it from firmware of from device ( ic ,battery , charging port or .. )
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
It’s usually either wrong firmware was flashed on the phone or phone was not factory reset in recovery mode after flashing.
SM-G928F, make sure that the firmware is the latest version for your phone as well. Try factory resetting first and see how that goes in recovery mode.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
i downloaded the last firmware but always turn off when i unplug the charger after 10 sec idn what i should do :(
댓글 달기
귀하의 답변을 추가하세요
rimon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 203
