주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
Console is not connecting to any wireless network
Okay so my console (which is an original xbox one system refuses to connect to any wireless network. Ive opened the console to ensure the wireless board isnt loose or anything, but its not. Controllers sync just fine (although they desync after the console is restarted) but my maun issue is wifi.
Here is a picture of the menu when I go to change networks (which none show up)
Any idea why its doing this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
I was able to fix it. I went out on a limb and tried replacing the Wifi cable. that seemed to have fixed it, so if anyone has this issue in the future, try replacing the cable. its a 15 minute repair.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
If you can 100% rule out an issue with the networks you are trying to use, it is likely a problem with the wireless card. I would suggest getting a new wifi board and switching it out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thing is, I thought as much. So, I pulled the wireless module from a known working system, and had no prior luck. With that said, the socket the wireless board felt... Weird... There was little to no resistance when plugging it in. And when I hooked the wireless board from the system I am troubleshooting into the good system I pulled the board from, it worked just fine...
PCB issue maybe.
댓글 달기
귀하의 답변을 추가하세요
William Bosco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 92
