주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
iPhone 6S Plus, no image
Hello iFixit forum users i have a question at the moment i have 6s plus, which one displays blank screen (no image), but u can connect to iTunes, it recognises i have tryed to swap, change LCD screen’s but problem stay the same no image. MY QUESTION WILL BE ON LOGIC BOARD WHICH ONE SMD DIODE, CAPACISTOR, IS RESPONSIBLE FOR LCD IMAGE? if any knows just write me down how they are named in Iphone 6s plus schematics. Thank u!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개:
May I know how does it get recognized. Does it get recognized as "iPhone in Recovery Mode". If not, it may be your LCD screen. Before replacing, inspect the pins of the LCD and see if it doesn't have any bent pins. If there are no bent pins, inspect your motherboard. It may have bent pins or foreign objects that may prevent it from working properly.
fully working iphone without any signs of image just blank screen i have tryed to change LCD same issue
댓글 달기
답변 1개
iPhone 6s and 6splus series have same issues that i solved on that cases that is the Chestnut related issues.First clear about that there is no light present but logo shows or not that is not the software issues anymore.Some capacitor near LCD connector causes that problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
maybe it's FL4291? i have tested that it shows me 0.650. i have tryed to test lcd connector on logic board its starts from left side when u looking straitght to connector just is that 0.650 is not too high? should be around 0.550 ? as i know ? ? what do you think ?
댓글 달기
귀하의 답변을 추가하세요
Darius Varanavičius 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 147
