주요 콘텐츠로 건너뛰기
The Acer Chromebook CB3-431-C5EX is a fourteenth generation Chromebook released in May 2016. The 14-inch Acer Chromebook 14 is made to have a full HD screen and up to twelve hours of battery life.
Acer Chromebook: blown motherboard component?
My father’s Acer Chromebook 14 (CB3-431) will no longer power-on. It worked fine for 18 months before one day it no longer charged. Once the battery ran down it no longer powers on.
I suspected the power port might be at fault, as the socket is quite loose. When removed the back I noticed a white mark on the motherboard near to what I believe is the charging circuit.
Now I am no longer sure whether it is worth ordering a new power port.
Does anybody know if this looks like a blown motherboard component?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It’s hard to tell from the picture. A blown motherboard component would have probably made a noise and emitted some kind of smell when it detonated. Also, the computer would have likely become symptomatic immediately.
It could be a blown component, or that white mark could be because of a manufacturing defect. Perhaps the unit is refurbished, or was otherwise handled by a technician who damaged it?
To make sure that the power port is at fault, I would probably first replace the battery and see if that doesn’t fix the issue. It’s always best practice to try the least invasive solutions first.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Steve Larkin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 355
