주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
Water damage iPhone 3GS
The other day I had the bright idea to go to the pool with my iphone in my bathing suits pocket. I wanted to listen to music but I found a way to forget my headphones. Anyways, so yeah I have my iphone in my pocket and once at the pool decided to jump in the water so I would find the water less cold. Thats when I realised what i just did and told myself: "please don't tell me you just did that". So yeah i don't even want to look at the phone thinking after once dropping it from a 2nd floor face on the ground (no damage) and once dropping it in the water with no damage, this time that was it. So I stay a bit at the pool feeling stupid and letting my phone dry to the sun. After 15 minutes, I decided to go back home and search "bring my iphone back from the dead". I find the rice trick do that for 3 days. Then open my phone put alcohol to kill any corrosion and stuff. Plug my iphone and too good to be true It opens no problem, i unplug it no battery problem, i start texting my friends its working and then when i want to go back realise... no more home button. First reaction ill open it again to see If i missed a spot and try turning it off... no more power button. So yeah i have my iphone back perfectly working, no lcd or battery problem and no data loss, but for my power button and home button... Has this happened to any of you? What should i do? I don't want to order a bunch of buttons to realise its not the button or whatever. Is there a way to diagnose where the problem is from? logicboard? button itself? Looking at the logicboard there doesnt seem to be corrosion or anything.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
sounds like you did a good start on the first aid. I'd let the phone"die" or run out of charge, then open it up and use the alcohol to clean the top of the dock connector (it makes contact with the home button) and then I'd clean all of the connectors on the motherboard and all the flex ends. allow it to dry and repeat the process. when it's dry again i'd reassemble and see what results you get. If still no home button, take a look at the gold prongs on the back of the home button and check you haven't flattened them taking the display off..lift them up a little. if still no joy on the power button is part of the headphone jack/volume/mute flex.. the guide is on the right. I'd look for a part that has the metal connectors already attached, not just the flex on it's own-it'll make life easier and there is usually not a lot of difference in price. the home button could be the dock connector or the home button flex.. more likely the dock.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thank you so much!! I just did what you told me and combined it with your water damage 3g iphone guide and now my Iphone is fully working!!
brilliant! glad to have helped and thanks for accepting the answer..it should help others in similar situations.
댓글 달기
답변을 추가하세요
Jean Sebastien 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 2,167
