주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
660 질문 전체 보기
iPhone 8 plus touch and freezing issues after screen replacement
I replaced the screen on an iPhone 8 plus with iOS 12.0 installed, a few days later the touch became intermittent, sometimes it works great sometimes and won’t respond. I updated to iOS 12.2 hoping to resolve the issue but the issue only got worse. screen sometimes would just freeze, I tab the messages app and it won’t respond after a few tabs now it works, screen is too sensitive, all apps could start to wiggle as if I touched and held an app longer that 3-4 second when in reality I barely touched it. I re-installed the original cracked screen and now it completely frozen, I installed a brand new screen and its still frozen. Please help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Hi Owen, thank you very much for your reply!
-I installed 2 new screens and it turned on frozen, I restarted the phone and it’s still frozen
-I went ahead and re-installed the original cracked screen it came in with, it turned on but it’s still frozen, I restarted the iphone and it’s still frozen.
- I now reversed the first screen replacement and i’m back to square one where screen works when it wants to.
I wonder if iOS 12.2 has something to do with it?
It might. Try doing a full restore by going into dfu mode and restoring it via iTunes.
댓글 달기
답변 3개
가장 유용한 답변
Try replacing the screen. It’s probably just a faulty screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Have change the screen and the problem is still the same
My phone is hanging so badly
@beauty64950 start a new post with your problem. More people will see it.
댓글 달기
i found this on my search, try it
'''iPhone 8 Freezing'''
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First remove the Home button flex and check that also cause such issues.This phone have 3d touch too this section makes such a problem.This will help you to solve that problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
info 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 1,536
