주요 콘텐츠로 건너뛰기
Breville Smart Kettle BKE825 How to stop the beep
Would appreciate any help with this, it’s so annoying even the dog leaves the room! It beeps when it boils, it beeps when you lift it, it beeps and you put it back on the base! I’ve bought a triangular screwdriver but can’t see where to go from here without destroying the base….ARGH!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
Chosen solution is incorrect. It beeps when you plug it in, it beeps when you start it, it beeps when you put the kettle onto the base, and it beeps three times when ready. Source: my parents have the %#*@ thing and it’s a nightmare.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Hold down the stop button for 3 seconds!
Hey, found a fix, check my comment below.
I was not able to get the beeping to stop with the button - but was able to eliminate it per the video. The part is under the PCB inside the base unit. Worked easiest to just remove the entire beeper instead of the metal plate.
댓글 달기
The actual solution is to hold down the stop button for 3 seconds, this will activate/deactivate the beeping.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
You mean the start/cancel button? That doesn't work.
댓글 달기
Why is there a beep? Honestly, so pointless. Fortunately this gent has solved the issue:
https://www.youtube.com/watch?v=cNZ-w5XY...
This kettle has the buzzer in the base, and it's quite not the same as in the video, you'll see a circular disc right underneath a seven-hole 'speaker' vent in the plastic you take off. Then snip the red & black joined wires. I cut back the excess and covered the ends not going attached to the buzzer in electric tape. Reassemble and enjoy your cupper in peace...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I know this reply comes a little late but I’ve just hacked mine by taking the base apart (if you don’t have a triangle screwdriver, you can use a small hex head or a small torx head) and removing the little disk from the piezo buzzer, as shown in the following video :https://youtu.be/cNZ-w5XYVZ8
%#*@, it’s so much better without that annoying beep!!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
brendamayart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 48
30일 전: 263
전체 시간: 10,392
