주요 콘텐츠로 건너뛰기
Service and repair information for the Huawei Mate 8, which was released in November 2015. It runs Android OS, v6.0 and sports a 6.0-inch display. In addition to a 16MP primary camera and an 8MP secondary camera, the Huawei Mate 8 also has a non-removable Li-Po 4000 mAh battery.
touch screen not working after lcd screen replacement
after lcd screen replacement touch was working fine but after few hours it stop working and then tried with other new screen replacement but touch screen not working but display is fine
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개
hi
I have this problem too, in the top of the lcd socket, some parts of resistants has been breacked
but i dont find this parts to reinstal them and exactly dont know this problem directly affected to touch or not.
How can solve this
댓글 달기
답변 1개
가장 유용한 답변
If the screen was an cheap-repleacement part then it could be not suitable for your device. The good practice is to manage a hard reset of your phone after any replacement in order to get a new drivers adjusted to your component. Try that and then you should consider an PCB damage - not only the connector but whole ICs itself. The first thing that goes off when some one not provided goes into the device is an backlight IC, but in your case it could be just touch circuit.
Try a new display after an hard reset of device. Then go back to this forum and get better answer than mine.
Ps. After reading your post over again I would suggest to check for water damages. If the screen stops working after few hours it could be some dirt/corrosion on the motherboard near chips/capacitors
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
darshan kumar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 9,418
