주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
2133 질문 전체 보기
Vizio CA24 stuck on PC Off when booting.
So I recently purchased a secondhand Vizio CA24 All in One Desktop. It was missing a hard drive, WiFi card, and ram which I supplied, yesterday I had it running windows but this morning it gave me a message saying PC off in the top right of the display, I took everything out of the computer and put it back in, but it still refuses to work! Any Ideas? Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi Jon,
Let me get this straight. I'm assuming you installed all the missing parts and then installed Windows and it booted up fine. Next day itwould not boot up>
Also
Specifically which model of Vizio CA24 is it?
What happens when you press the power button?
Do any lights come on?
Can you hear anything?
Can you get into the BIOS? Usually one of the following keys - F1, F2 orDel.
Did you check that all the cables are correctly connected?
When you took everything out of the computer were you careful to discharge any static?
Let us know.
PSU failure? Fried chip? Imcompatible RAM (Since it's an OEM PC)
댓글 달기
답변 1개
선택된 답변
This is a well-known problem with the Vizio CA24 computer. Since it seems to be a manufacturing defect unique to the Vizio CA24, your best bet may be to contact Visio customer support directly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi, how I get actually bios update for VIZIO CA24-A2
But the home page of VIZIO don't have any support
댓글 달기
귀하의 답변을 추가하세요
Jon The Otaku 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 1,091
