주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
MBP Early 15 sudden hangup with Kernel Panic and restart
My Mac book pro early 2015,
Suddenly hang with no visible reason and I’m getting the following report.
What is the reason ? any help?
Current Version 10.14.4
last time it was connect to Magsafe, suddenly the cursor changed as the system busy and restarted.
I tried Diagnoses by pressing D, and got ADP000 No issues found.
Panic Report April 22
Disk First Aid Report
Model: MacBookPro12,1, BootROM 182.0.0.0.0, 2 processors, Intel Core i5, 2.7 GHz, 8 GB, SMC 2.28f7
Graphics: kHW_IntelIris6100Item, Intel Iris Graphics 6100, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.77.61.2 AirPortDriverBrcmNIC-1305.8)
Bluetooth: Version 6.0.11f4, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
USB Device: USB 3.0 Bus
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The two error conditions:
  • 14=page fault, registers …
  • Root disk errors: "Could not recover SATA HDD after 5 attempts. Terminating."
The errors are telling me your system is a bit undersized for what you are trying to run with only 8 GB of RAM and a small 128 GB SSD. What happens your system leverages the drive as Virtual RAM (V-RAM) which is running into trouble as it can’t allocate free space on your drive. Think of it like a glass you are filling and you keep filling it beyond what it can hold spilling over. Unlike our example we need every bit of what you are filling the glass with as soon as we loose some we get into trouble!
You have a few issues here:
  • Your drive is too full! Maybe its time to get a bigger drive.
  • Your drive is likely worn to the point it will need replacement soon which will require a new drive.
Check out OWC as well as Transcend for a compatible SSD
Get a large enough drive so you keep 1/3 to 1/4 free so your system has some space for V-RAM, paging, and depending on your app caching & scratch space.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks, @danj I changed the SSD and it works fine, for now, I'll try it for a while and check the problem again.I'll keep you informed.
Mahmoud - What size did you put in?
If you're all set don't forget to accept the answer.
댓글 달기
귀하의 답변을 추가하세요
Mahmoud Shokry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 612
