주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
New battery. MacBook turns off when charger is unplugged
I followed the FixIt guide for replacing a battery on a MacBook Air Early 2015. My older battery was having trouble keeping the charge. I let it charge to 100%, then let it continue charging for two more hours. However, after setting the energy preferences so that he Mac would not turn off in order to deplete the battery, when I unplugged the power adaptor my mac turned off. I tried everything to fix this problem (SMC reset, PRAM reset, re-installing the new battery etc.). Why is this happening?
Here are some screenshots from CoconutBattery:
EDIT 1:
After checking the battery under “About this Mac” I get the following information:
CoconutBattery is saying that my battery is charging, by my Mac itself is saying otherwise. Why is this?
EDIT 2:
I reinstalled the old battery, but now this battery is not charging either. When I disconnect the power adaptor, the macbook continues to turn off. What is going on?
EDIT 3:
I performed a SMC Reset on the older battery ( removing the battery, holding the power button for 10 seconds, re-installing the old battery, pressing the power button) and now it seems that this battery is charging. However, I did this multiple times with the newer battery and it does not charge. Thoughts?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
What color is the MagSafe LED? Amber or Green
It is green, and on the top right corner the battery icon says 100% charged
댓글 달기
답변 2개
가장 유용한 답변
Lets check the MagSafe charger as you might have a bad cord (damaged) or the MagSafe connector is not making contact. Review this Apple T/N Find the right power adapter and cable for your Mac notebook and you could also have a bad/fake charger OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Compared- Fake vs Genuine Apple Magsafe Chargers - YouTube
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Pretty much a bad battery, if the old battery doesn't do this it confirms it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
@benjamen50 - I'm not sure thats the case here. I would reset the SMC to see if that altered things.
I reinstalled the old battery, however now this battery is also not charging. I included photos in the original post
댓글 달기
귀하의 답변을 추가하세요
Arthur 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 249
