주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
질문 마감됨
Iphone doesn´t start anymore after display chage
Hello,
i got some small to huge problems. After changin the display my iphone doesn´t start anymore. I took me some weeks to remove the old display and assmble everything. So could this be the problem?
I tried to connect it via usb but nothing happens, also i tried to press and hold the home and on/off button for more than 30 secs.
Nothing happend so far.
Thanks for your help..
Cheers
Jan
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Mine too dont know what to do now
댓글 달기
답변 4개
선택된 답변
This happened to me.
After replacing the screen, it continually displays the apple.
It appears that the ribbon cable labelled 3 was not correctly in place. Once this was corrected the iPhone runs fine.
Luc.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sounds to me like one of the many ribbon connectors isn't seated properly. Best dismantle it again and check they are all pressed firmly into place.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
even i hv the same problem...i assembled it again but still its not turning on...
댓글 달기
this happened to me
i coulld even call the phone and it would ring but i couldnt pick it up
turns out that the top right power button needed cleaning, was a bit dusty
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 1,291
