주요 콘텐츠로 건너뛰기
Mac mini가 오랜 기다림 끝에 새로워졌습니다. 프로세서 옵션에는 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5 및 3.2GHz 6-core Intel Core i7 프로세서가 있습니다.
85 질문 전체 보기
Macmini 2018 RAM upgrade void warranty
Hi,
I’m having T2 chip problem with my Mac mini 2018, and also i upgrade ram my self 8gb to 32gb. so can i claim apple warranty for T2 chip problem?
Also, I purchased my mac mini from USA but i live outside USA. how can i claim warranty?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
What issues are you having with the T2 Chip?
As for the warranty goes, while you may be able to get away with sending the 32GB ram in with the machine but I would reinstall the 8Gb before sending it in. You can visit any apple store for the repair or just call the support number.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks for your answer.
I am getting random reboots and glitch screen, Sometime it’s don’t show for a day some time 2/3 times a day.
I’m using latest version of macos mojave 10.14.4
There is no hardware error with apple hardware check.
{"caused_by":"macos","macos_system_state":"running","bug_type":"210","os_version":"Bridge OS 3.3 (16P3133)","timestamp":"2019-03-05 19:25:49.76 +0000","incident_id":"EA706255-8D43-48A8-81C4-DF5240B37CC7"}
"build" : "Bridge OS 3.3 (16P3133)",
"product" : "iBridge2,5",
"kernel" : "Darwin Kernel Version 18.2.0: Wed Jan 2 20:41:23 PST 2019; root:xnu-4903.241.1~3\/RELEASE_ARM64_T8010",
"incident" : "EA706255-8D43-48A8-81C4-DF5240B37CC7",
"crashReporterKey" : "c0dec0dec0dec0dec0dec0dec0dec0dec0de0001",
"date" : "2019-03-05 19:25:49.72 +0000",
Hmm, what makes you suspect the t2 chip then?
iBridge2,5 & RELEASE_ARM64_T8010 cinch's the T2 is having problems. There's been quite a few reports on this issue.
댓글 달기
Yep this is a T2 problem. You’ll need to put back the Apple memory then bring in the system. technically you shouldn't need to swap the RAM again. Some Apple employee’s give people a hard time when they’ve upgraded their Mini’s, unlike the 27” iMac’s you need to pop the case off.
Double check your RAM is the correct spec.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Shokat Jamil 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,646
