주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
White screen after replacement, but differently.
I have gotten the famous white screen after replacing the screen, but this time it's a bit different. The screen only turns on when iOS boots up, and never shows the apple logo at all. I'm completely stumped by it because the original screen works perfectly well, it's just in horrible shape. The replacement worked fine when I first installed it, and nothing I've done, not even a restore, will seem to fix this issue. I've even tried the power+vol up+home combination and got absolutely nothing. I'm worried I'll have to refund the screen. If anyone has a solution to this I would appreciate it rather greatly.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Did you try another new screen already?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
@douglasvinicio I haven't had the money to order another one, so no. I just have the replacement I already purchased and the original
In base of my experience if your original one is working,your motherboard and FPC connectors are fully functional. So i would assume that is just buy and install a new screen to solve your problem.
댓글 달기
Sounds like the screen may be faulty? Get the manufacturer to replace it and see if that fixes it :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@ran9aa I will give that a go.
댓글 달기
귀하의 답변을 추가하세요
SolarisTheBat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 49
