주요 콘텐츠로 건너뛰기
The Latitude E7440 is an ultrabook by Dell released in November 2013, identified by model number 730-6964, with a fully usable touchscreen display. It is a high end business laptop built to be portable and sleek yet sturdy.
14 질문 전체 보기
질문 마감됨
Black screen on boot, no backlight BIOS reports “unknown panel”
I’m having a problem with the screen, it never turns on, the last time it was on it went blank white(which is also what it does when I try to run the lcd built-in-self-test), then never came on again, the bios says “unknown panel” I’ve replaced the screen cable but it still doesn’t turn on, and the bios still says “unknown panel”, could the panel have failed?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If BIOS is not recognizing the LCD panel, perhaps flashing the BIOS to update it will help.
Also, is BIOS giving any “beep codes” when you first turn your computer on?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I’ve already tried this, and it made no difference, no it functions normally other than the screen not working, thanks for the help though
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 10
전체 시간: 376
