주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
LCD flex over battery connector
Hi.
After replacing the screen on my iPhone 6s the LCD goes dark when pressed around where the battery connector is. The battery is also new but the problem didn’t occur with the old screen in place. 3D Touch barely works because of it.
What I’m trying to figure out is whether the new screen is faulty or not.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Is there a foam pad on the battery connector? A lot of replacement batteries make this pad too thick and it causes your metal bracket over the battery connector to not sit flush. Remove that foam piece.
The 3d touch barely working is the screen itself. Unless you purchased an original refurbished replacement screen your results will vary on 3d touch functionality. I’ve seen where the best aftermarket screens will still give me mixed results from working perfectly to being too sensitive or flat out not working.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
No foam pad on the connector, the battery claims to be original.
Ok, in that case, it's the screen. I've seen this on aftermarket screens. Original refurbished screens aren't that expensive for the 6s. They average $30.
Yep, I just tried using the screen while detached from the body and the problem persists. Thank you!
댓글 달기
귀하의 답변을 추가하세요
Axel Hellberg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 46
