주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Blue light then powers off
Hello,
I’m working on a PS4 that’s suffering from a problem I’ve seen mentioned several times on here, and none of the ‘easy’ solutions have worked.
Attempting to power on, the blue light blinks for 7-8 seconds then the console powers off. Well, it seems to, but several power rails are still present and pressing the power button again in this state causes it to turn properly off. This is different to the common “blue light of death” fault where the light supposedly continues flashing until you power the console off so I’m reluctant to try things like putting extra pressure around the APU just yet.
I noticed also that the USB ports have no power present during the power-on attempt, I don’t know if this is normal, but the ports have clearly been replaced before so I’ll assume there is some fault with the USB hub controller chip or power circuitry.
Given these symptoms, is this likely to be a USB fault? Or should I try other fixes first?
Thanks.
UPDATE: The TEST signal on the USB hub controller chip is reading 3.2V which means test mode enabled. Is this ever meant to be the case? I don’t see any traces going anywhere visibly besides a probe/test point, but I realise that the signal may be going elsewhere on internal layers. I will replace the chip just in case this is not meant to happen and is the cause of a failed POST.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
A friend of mine had this problem he was told to blow the ps4 with an hair dryer for 20mins on warm back n forth because they get hot the solder sometimes melts and resets slightly off my son tried it worked as a temporary fix
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@bev2304 I may attempt a basic reflow around the areas that could be the problem to see if it helps at all, but I understand that this is almost always just a temporary fix, and also it doesn't provide much knowledge of the fault in order to fix it properly at a later date.
I've already ordered some USB hub controller chips so I'll just try replacing that first.
댓글 달기
답변을 추가하세요
Kasane Kona 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 269
