주요 콘텐츠로 건너뛰기
A collection of guides and support to help with washer repair.
3478 질문 전체 보기
Soapy clothes in washing machine
Clothes are still soapy after washing cycle has finished. I have cleaned the machine, used white vinegar to get rid of soap suds, the machine runs clear on an empty cycle. I have changed washing liquid and using only a small amount. The machine is draining, the pump isn’t making any weird noises, I’ve checked the filter, checked for blockages in pipes and water is running through. What else can I try? Thankyou
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
  1. Too much Detergent added.
  2. Overfilled Washer.
  3. Drain Pump not working or clogged.
  4. Drain Hose may be bent or clogged.
  5. Water Supply Hoses bent or kinked.
  6. Water Supply Valves not fully open.
  7. Switch or Control Board malfunction.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
EmmaSmith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 175
