주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vizio 42" LED TV released in September 2012.
No Video or Audio
Hello, I have a Vizio LCD TV that I found near the trash can at my building. When I try to turn the TV on nothing comes on except for the LED power indicator and then it fades out after a few seconds (which I learned much later that is normal for this tv). But I bought a used power board and then a used video board and nothing changed with the TV.
I am thinking that there is a video board problem. I am considering buying another video board.
Shouldn’t I get something on the screen after replacing the video board? Is the problem definitely within the video board?
This is how the TV looks on the inside.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
djchitown do you at any point get any audio? Have you measure the voltages coming from the power board to the main board? Besides changing the boards, what have you checked?
I don't hear any audio. I am not sure if the TV plays any audio on power on. I don't know how to use a voltage meter and not sure how much voltage is supposed to come of certain cables.
댓글 달기
답변 1개
I had that problem witrh my Samsung and replaced the main ogic board and it worked. Ithink it could be any one of the 3 boards tho. You will have to check the voltages with your multi meter. Chek out youtube. Tampatec has a good video on checking voltages.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I am only away of two large boards inside of the TV. Is there a 3rd?
댓글 달기
답변을 추가하세요
djchitown 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 138
