주요 콘텐츠로 건너뛰기
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 질문 전체 보기
My controller wont charge
I have tried resetting but it’s not working and i tried opening the controller and seeing if the charging port is damaged but it was fine and the battery isn’t damaged because the controller lights up for 5 seconds before it dies but my other controller is charging and with the same cable
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Still could be a bad battery, if you have a digital multimeter can you measure what voltage is on the battery? They should be hovering around 3.7V-4.2V.
Any lower may mean that the battery may have to be jump started with a DC bench power supply.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Mahmoud1432 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 46
