주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
204 질문 전체 보기
Macmini 2011, Green Apple logo on boot and then permanent white screen
I was normally using the Mac mini with an external HDMI to VGA monitor then suddenly the monitor started showing vertical lines. On a restart it showed Green Apple logo and then permanent white screen without login screen. I have backed up all my data to external USB by booting in User mode so the internal HDD is working properly. I think the graphics card has failed. What are my options other than replacing the logic board?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I believe your diagnosis is correct.
Here are the previous responses to this problem:
2011 Mac mini GPU failed (Radeon 6630M) - repair options?
I have had some success on the 2011 machine using gfx to turn off the integrated graphic
https://gfx.io
  • Manually switch to Integrated Only or Discrete Only mode to force one GPU on or the other.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Thanks a lot for your suggestion. Gfx is an App, how do I run and configure the app to turn off integrated graphics when the MAC does not boot. Is there any tutorial to turn it off in user mode?
I have to install it using another Mac and then set it, and then put it in the defective machine.
There are tutorials out there such as on the Apple discussion boards,
https://discussions.apple.com/thread/750...
that describe moving the kext files for AMD GPUs to another folder so that the system defaults to the Intel GPU. But without access to Recovery mode so that you can switch off SIP using csrutil disable, I’m finding that I get the ‘operation not permitted’ message and the files don’t move.
Anyone know how to get around that?
@clumhor - You'll need to use a second Mac system via Target Disk Mode to gain access to the Mini's HD to delete the KEXT files for the dedicated GPU.
@Dan - I had (finally) worked out that this might be possible, so thanks for confirming! Strange that other threads on other forums suggest some people have been able to move the kext files in single user mode without being able to access Terminal to disable SIP. Will try hooking my Mac Mini up to my MBP and move the kext files that way. Will report in if that works - or if it doesn’t.
댓글 달기
귀하의 답변을 추가하세요
Imran B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 5
전체 시간: 663
