주요 콘텐츠로 건너뛰기
Repair guides and support for electric and gas powered high pressure sprayers, sometimes known as power washers.
34 질문 전체 보기
No pressure in my karcher2
I put a bin liner loosely over my karcher 2 because it started to rain,then went back to the spraying and forgot to take the bin bag off.
it ran for a while,then made a awful noise,and I was very quick to turn it off.it will turn on but there is no pressure,can you please help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi John,
Sorry to hear! Have you tried clearing the unit in case air is trapped inside? Here is a guide from Karcher’s website.
To bleed the pump of any air, turn the machine off and disconnect the high pressure hose and trigger gun from your power washer. With only the garden hose connected to the machine, turn on your water source and allow water to run through the pump of the machine for 20 or 30 seconds. Turn off the water and connect the high pressure hose and trigger gun and try using the machine again.
http://www.karcher-help.com/index.php?/K...
Have a look through the above link as well.
I hope this helps in some way.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you mark,but I’ve already tried that option
댓글 달기
귀하의 답변을 추가하세요
John Richards 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 239
