주요 콘텐츠로 건너뛰기
2003년에 출시된 Apple의 휴대용 소비자 컴퓨터 iBook G4는 iBook G3를 대체하였습니다.
530 질문 전체 보기
How do i install the software to my crashed ibook g4 laptop?
I bought a ibook g4 laptop on ebay, and it crashed a couple of days later. So i bought the software on ebay and when it says to click on the device that you want to install it on, nothing comes up. What should i do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Can you tell us which iBook you have and what software you bought?
댓글 달기
답변 2개
가장 유용한 답변
This means that it is not picking up your hard drive as a bootable volume. You need to look at the hard drive in disk utility and verify that A. the drive is show and B. repair the drive through the first aid function in disk utility. If the drive is not shown at all here then you will most likely need to check the connections to the hard drive or perhaps just replace the drive.
Best Regards,
Xen
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i tired the first aid, but it didnt work, it said there was an error. how do i check the hard drive, and what else should i do?
댓글 달기
From here you would proceed to reformat or repartition the drive. This will remove all of the data for the drives, so if you have anything to save on there attempt to back it up or look into data recovery. Then proceed to install the operating system.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ray 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,177
