주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Does it make sense to do three repairs at the same time?
There are three repairs needed on my iPhone 6S Plus: The glass is cracked, the external speaker plug is no longer functioning and the microphone no longer works. Would it make sense to do the three repairs at the same time? By that I mean, that it may be necessary to remove the same parts in order to access the malfunctioning parts, or similar.
Thanks,
Lou
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Since you have a faulty microphone it might be that the loudspeaker may be still in order and not working just as a consequence of a faulty lightning connector. However, since the cost of a loudspeaker is quite modest if you’re planning to replace the dock by yourself, in my opinion might not be worth saving on the part to avoid to risk wasting further time and reopen the phone for a cheap spare. I’d suggest you buy and replace all at once. Here’s the guides to help you:
iPhone 6s Plus Screen Replacement
iPhone 6s Plus Lightning Connector and Headphone Jack Replacement
iPhone 6s Plus Lightning Connector and Headphone Jack 이미지
안내서
난이도:
운영
1 - 2 hours
iPhone 6s Plus Screen 이미지
안내서
난이도:
운영
30 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
The cost of a new display for a 6S Plus is still only a fraction of what a new device would cost you. Even a high quality part would be cheap, compared to a new phone. A new main speaker and charging flex (where the microphone is located) are very cheap parts. The 6S Plus is quite easy to repair, and we do have excellent guides here on iFixit to help you.
Here in Sweden, a refurbished 6S Plus would cost you around 300$, and a brand new one around 400$.
If you do the repair itself, a new display might cost you 90$ and a new speaker and charging flex maybe 25$. If you shop around, there might be even cheaper options, i got these prices from one of the bigger parts retailers (https://www.teknikdelar.se/) in Sweden (Sweden is a quite expensive country mind you).
So yes, in my opinion, it is worth doing these repairs, even at a repair shop. Considering these repairs might cost you around 100$, this is a small price compared to the 3-400$ to buy a new exact same model.
Hope this helps!
/E
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
loudanzico 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 47
