주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
467 질문 전체 보기
Can I add discrete graphics to Mid 2014 MacBook Pro
Hi I have a retina macbook Mid 2014 with intel Iris graphics and wondered if I could add discrete graphics to it as an upgrade?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
There’s no way to do that.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
This series came in two different configurations:
Intergrated Graphics
Dedicated Graphics
The logic boards are physically different! You can't add the GPU chip. You can only swap out the logic board which would be expensive!
Thanks Dan - that answers my question
댓글 달기
If it was the 2016 or newer model with Thunderbolt 3 ports, I would have advised you to research the possibility of using an eGPU. I don't believe this is available for the model you have.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
There are a few eGPU systems which work via Thunderbolt-2. At this point it would be a used unit.
댓글 달기
귀하의 답변을 추가하세요
Jeffers De Maio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 262
