주요 콘텐츠로 건너뛰기
1.6 또는 1.8 GHz dual-core 프로세서, 2 GB 또는 4 GB SDRAM, 64 GB 또는 128 GB SSD
192 질문 전체 보기
MacBook Air without battery is having date/time issues
I’ve been running my mid 2011 macbook air without its battery because it swelled up. Today when I started it the date and time are wrong and won’t update automatically even though I’m connected to wifi. It also can’t determine my location. Is this something that replacing the battery could fix, or is it unrelated?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Without a battery volatile data get lost when you unplug the Magsafe, that’s normal and a new battery will surely fix the issue. No idea why time and date wouldn’t update though, double check your settings in system preferences..location services need appropriate privacy permissions.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I’ve checked system preferences and also reset the PRAM, still no luck
Your system will learn the date & time from the network time server Apple offers but it will be based on the default time zone, it does take a bit of time for the connection to establish.
You really should fix your system with a new battery.
댓글 달기
귀하의 답변을 추가하세요
Max Richmond 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 168
