주요 콘텐츠로 건너뛰기
Clothing iron/다리미는 flatiron/플랫아이언 또는 iron/아이언이라고도 불리며 보통 가열된 삼각형 표면으로 천의 주름을 잡습니다.
85 질문 전체 보기
Does someone know how to disassemble Philips PerfectCare GC9220 iron
Hello,
Does anyone know how to disassemble part 17 on page 4 of the service manual ?
https://www.manualslib.com/manual/953960...
One of the switches is not working anymore and I’d like to fix it.
thanks!
Benn
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @benoitmagicien
Well I guess
Most probably you need to get this
iFixit Opening Tool
The plastic seems to be clipped
take note on the red catch of the plastic when your remove
iFixit Opening Tool 이미지
상품
iFixit Opening Tool
해당 답변은 도움이 되었습니까?
점수 1
댓글 7개:
Hi,
Thanks for your input, actually, the red catch I can get out easily, the whole back part is also not attached, so those things are not plastic catches.
Basically, i can lift the front and the back, but it's blocked by something (probably plastic catches) around the whole in the middle. And I can't get to the screws you circles without removing part 17 first...
Hi @benoitmagicien
work slowly, if you have a opener, that's great, else if have a used credit card, can slot in and try removing it, but slow and steady.
If you feel there are a lot of resistance or suspect there is a screw, slow down or stop.
There is a lot of resistance, but there is no screw to access.
Here's what it looks like from the top :
https://images-eu.ssl-images-amazon.com/...
able to take out 18 and part 13 first?
That seems like a very very good idea !!
I'll try that first thing when I get home and keep you posted !
Thanks !!!!
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
Benoît DESTRUBÉ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 1,314
