주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
White Screen Startup No empty Folder
I have seen another post about this but it looks like it fell apart. There was no good result in that one so lets get s good one in this one.
Boots, Chimes and engages all devices (fans, dvd, speakers).
Lights up all four LED on board.
Continues to run but never shows apple or empty folder.
The following have been done with no success.
-Replaced HDD
-PRAM reset
-Commnd+C restart
-Safe restart
-load OSX disc and attempt hardware test
-Replaced Memory
-Swapped a good screen into it
-tried to use a 2008 20" iMac board but got a strange repeating chime... dont think it liked a board from another model.
Now I need some other logical thoughts.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
Hook it up to an external monitor and see what you get.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hello, i got the same problem and hooked an ext. monitior. and there is an blank dekstop were i cant't do anything, but only create a folder and look at it.
Jan
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This is a different type of problem. Please start your own question and elaborate on being able to create a folder. Do you also show a curser?
댓글 달기
귀하의 답변을 추가하세요
Erik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 662
