주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
Broke the keyboard cable latch
I've managed to break the latch flap and now I can't use the keyboard anymore.
I tried to place a thin plastic underneath to hold the ribbon in place, but no luck.
It looks like I have to replace that connector. Does anyone know the part number for that and where to buy it from?
If there is other option, please advise.. Thanks, Dan
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You’ll need to check with good light and magnification if you really broke the part or have just dislodged it. The flap has two small hooks that keep it in place. Unless you broke the soldered part you may just need to put flap back in place, otherwise you’ll need to solder the new connector to the board. Never seen those parts for sale anywhere, you’ll likely need to find a broken board for parts.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Dan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 71
