주요 콘텐츠로 건너뛰기
The SanDisk microSD card is a storage device/medium in the TransFlash/microSD format. The standard ones come in all different capacities, up to 2GB. It was released in October 2001.
15 질문 전체 보기
SD Card storage not detecting... Showing 512kb
I got a SanDisk Ultra 16GB memory card… First when I open my files on phone, all files name inside memory card was changed to hex keys and lot of new files… Inside the file was my original file…
I shocked and rebooted my phone… Then, the message corrupted started to appear… So quickly I plug it to my laptop and started to recover with MiniTool Recovery… The recovery was more 1GB, due to free version I can't able to recover all the files… I just with some images…
Then, I tried to clean the memory card contact with eraser… When I plug it back it can't detect anything… In Disk Management it's show 1MB drive, in diskpart on cmd it's shows 512kb, in chkdsk it's shows RAW, and in MiniTool it not detecting partition.
I wish I'm able to recover the files… I don't care if the memory card not working, I just need the data…
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
Hi, I have to say, probably the drive has been physically damaged. Under this circumstance, you may need to send the drive to a data recovery center for help.
I suggest you do NOT make any tests or scanning on the drive.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I think u lost your data try to format sd card and use recover toll or try this article may help u https://geeksadvice.com/fix-sd-card-not-...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Common Causes of SD Card Corruption
  • Interruption in SD card Formatting
  • Insert or Remove SD Card Improperly
  • File system corruption
  • Bad sectors
  • Virus or Malware Infection
  • Bad quality of the flash chip
  • Unstable SD card reader
  • Physical damage
Fix Corrupted SD Card Using Non-Data Loss Solutions
Solution 1: Try Another USB Port or SD Card Adapter/Reader
Solution 2: Use on Another PC/System
Solution 3: Clean the Golden Finger Pin
Solution 4: Show Hidden Files Stored on the SD Card
Solution 5: Recover Data from the SD Card Using Bitwar Data Recovery
Fix Corrupted SD Card Using Advanced Solutions
Fix 1: Use Error Checking Tool
Fix 2: Use Chkdsk Command to Fix Corrupted SD Card
Fix 3: Use Windows built-in Troubleshooter
Fix 4: Assign a New Drive Letter
Fix 5: Update the SD Card Driver
Fix 6: Diskpart the SD Card Without Formatting
Fix 7: Convert the SD card to FAT32
Fix 8: Full-Format the SD Card
Fix 9: SD Card Repair Tool Provided by Manufacturer
Source URL: https://www.bitwarsoft.com/fix-corrupted...
Note: Please note that a data recovery software is working under the read-only mode which accesses all the possible data from your SD card, it won’t damge/modify any of the data on the SD card, which means you can try to scan the data but please do remember that not to reuse the SD card including apply the solutions mentioned above.
After getting your data back, you can then try to fix the corrupted SD card as wanted.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yugathes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 22
전체 시간: 2,098
