주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Has anyone tried the new home button replacement solutions?
After trying all the other home button solutions for 7/7 pluses and 8/8 pluses and being really disappointed, we were curious if anyone has tried this yet. It’s a non bluetooth solution and appears to not need the charge port replaced as well. Claims to be plug and play.
If you’ve tried this solution or have good knowledge of it, please share your results.
https://www.mobilesentrix.com/home-butto...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Have a look at this recent thread where @benjamen50 has some interesting info he shared: Can you still use home button after replacing Logic Board?
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
ah ok yeah im very aware of the first two variants of home buttons. those bluetooth things were a semi novel idea but like you said, unstable. we were not able to use them for corporate repairs because of the way our MDM is set up (bluetooth does not function until the end user enters their credentials).
we'd like to try a couple and see if they work, but they are currently sold out as soon as they get new ones in. interested to see how they perform long term.
@chriskennedy44 I'd be inclined to think is out of stock because of the side issues/damages it seems to be causing. In case you try it out please keep us updated with your findings.
we just got a few of the new style buttons in to test. will update this post with results
댓글 달기
we did finally receive several of these new (YF) versions of the home buttons. they do “work”, and give haptic feedback, but are very glitchy. Several times there have been random black screens that took several minutes to recover from, and at least one boot loop. The buttons also seem to get warm, and have sluggish performance at times, as if it has a delayed reaction. I cannot, in good faith, recommend using these current buttons unless they work out the bugs. If i have any say so in the matter, we will not be sending out any of these to end users.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris k 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 3
전체 시간: 313
