주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Dropped iPhone 4, Touch Screen not working.
Hi
I dropped my iPhone 4 and now the touch screen is not working. I can see a hair line fracture in the panel behind the front glass panel. Everything else seems to be ok.
Please advise what parts would I need to replace?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 달기
답변 6개
가장 유용한 답변
Sounds like the digitizer has been broken. You will need the following part to repair your device.
iPhone 4 (GSM/AT&T) Screen
iPhone 4 (GSM/AT&T) Screen 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
+ sure agree with that. The crack that is visible, probably destroyed the digitizer circuit...
댓글 달기
If you have tried changing the touchscreen and still touch is not working, That means your phones touchscreen controller (IC) is faulty,
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The digitizer connector has probaly become dislodged slightly I have fixed many by opening the back and reseating the digitgizer cable. This is much more common when someone has removed the emi shield from the back of the board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yup, you just need the digitizer. The LCD and digi come as one part so it should be an easy fix. If your not sure how to see youtube or get a pro to do it. You can buy the part here on this site or try other sites like;
digiexpress.com
ipodrefresh.com
rapidrepair.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Will replacing the screen fix the problem of the semi responsive screen problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i dropped my iPhone 4, it fell, the fall formation preceded by the lower part and its near the iPhone speaker and the bottom part of the screen does not work and this is the only part that is not working
can you give me some tips to fix my phone with that problem of it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anuj Mathur 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 17,002
