주요 콘텐츠로 건너뛰기
식기 세척기 수리와 분해 안내서 및 지원.
707 질문 전체 보기
Whirlpool Dishwasher starts after keeping the door pressed manually.
Hi, I have an Ikea whirlpool dishwasher. It had a free fall door because hinge string was broken which I replaced. Now, it starts when I keep the door pressed manually. It runs for sometime even if I stop pressing the door but stops after sometime. If I presss the door again then it starts again but stops after sometime if I stop pressing the door. I already open the door and checked all the wires and everything is connected. I also cleaned the area for clogging and anything stopping the close the door properly. Could it be door latch or something else need to be replaced?
Thanks
Vikas
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
I need your model number to be able to locate parts.
Hi Mayer, Thanks for your reply. It's integrated whirlpool from Ikea. I can't see actual model details. It has service no. as 854586701001 and serial no. as 990740072630.
See if you still have the operators manual, iy will have the model number. I can't find the correct parts without it.
댓글 달기
답변 1개
가장 유용한 답변
it sounds like the latch is not working like it should , when you close it the latch on the shell not the door is not pushing in the switch to turn it on , check it out ans it should have an adjustment , screws or a screw to adjust let me know
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
I can't see any screw for the adjustment of the latch.
Thanks gadget1961, you were spot on. There was some misalignment between latch and the door tilt lock. I happened perhaps when the door spring-thread was broken (which I had replaced earlier). I opened everything and checked carefully and set it back and everything is working as normal :) . Thanks a ton to give new hope !!
Good glad I could help . I am a maintenance super 34 years for an apt community. We fix all our appliance's and then some
댓글 달기
귀하의 답변을 추가하세요
Vikas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 884
