주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
won`t power on when charger connected.
my mac wont turn on while charger connected. Only powered on by removing the charger and after power on every thing works fine and battery is also charging fine no issues. And some times wont came out from sleep
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I would follow apples guide it could be a PRAM reset or NVRAM reset
https://support.apple.com/en-us/HT204267
It sounds like something is causing a short so you can try to replace the charging port itself before doing that and spending the money try apples guide then if that doesn’t work backup and do a factory reset.
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
I tried it already but didn't worked
replaced with my friends mac didn't solve the issue i think its bios chip( bcoz some times it wont turn on from sleep)
oh yeah it fairly well could be.
댓글 달기
귀하의 답변을 추가하세요
Avinash 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 55
