주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
NFC quit working after charge port replacement
I work for a local phone repair shop. Me devices don’t come back with issues after a repair. However, after changing my charge port, my nfc is no longer working. No Apple Pay and I can read my wife’s Freestyle constant glucose monitoring device. I have checked all connection an found nothing wrong. I have also done a factory restart to no avail. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Pay close attention when removing the logic board on the 8+. The NFC portion of the logic board is located on the top right hand corner. The stand-off screw, just below the the one holding down the camera shield, also has a black plastic ring that it goes through. When you replace the logic board make sure that ring is on top of the logic board and not underneath it. If not paying close attention you will miss this. That ring is part of a short connector that wraps around the cameras to the top right hand corner of the frame. The NFC uses the frame as an antenna. Apple Pay will not work if this step is missed, nor will anything using NFC.
이 답변이 도움이 되었나요?
점수 5
댓글 2개:
This worked! Thank you so much for sharing your wisdom. God bless you (:
very helpful! Thanks!
댓글 달기
답변을 추가하세요
Darin Barfield 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 1,104
