주요 콘텐츠로 건너뛰기
9th generation of Chevrolet's full sized SUV, based on the GM GT800 platform.
30 질문 전체 보기
Why won’t my truck start?
About a month ago, my truck refused to start up, so I left it alone in my garage. Today, June 12, I have attempted to repair it. I’ve replaced the battery and the starter, yet it still makes a “dry and wheezy” ignition noise before remaining dead. I first just replaced the battery and tried to start it, then I replaced the “torpedo-like” starter, started it (didn’t work) and jump started it. Any ideas on what to do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If it's turning over but not starting check to make sure the fuel pump is working, turn ignition key on but don't try to start, you should hear a faint pumping sound or humming for 3-5 seconds as the pump builds up the pressure needed to start the engine. If you hear nothing, check the fuse for the pump.
If fuel pump is working,
Check to see if your spark plugs are emitting a spark. Remove a plug and put plug wire on, have someone turn ignition key and observe (without touching wire or plug) that there is a spark arcing across the contacts.
If you have fuel pressure and a spark the problem could be with the timing belt or chain and gear, if that is the case you should
bring your truck to a certified GM mechanic.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Xane Bornstellar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 32
전체 시간: 646
