주요 콘텐츠로 건너뛰기
Galaxy S7 Edge는 Samsung의 2016년 주력 휴대폰 Galaxy S7의 곡선형-스크린 버전입니다. 2016년 2월에 발표되었으며 3월 11일에 출시되었습니다. 모델 SM-G935.
369 질문 전체 보기
S7 edge has service after repair, cannot make or receive calls.
Hello, I just replaced the screen (and frame assembly) of this s7 egde, and everything seems to be working fine, however, I cannot make or receive calls. When I try to call, the phone app shows dialing for a second and then shuts off, and when I try to call the phone, it goes straight to voicemail. I do however get LTE data and can send out and receive text messages, oddly. Any help would be much appreciated. Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Did you replace the screen lcd that comes with the mid frame or did you buy them separately? I am in the process of doing a replacement of the whole phone, and noticed that the new mid frame seems to be missing the tiny square contact points that coincides with the motherboard. The old one has them.
댓글 달기
답변 1개
there are couple of reasons for this. one might be your antenna cables are not on properly. the signal antenna is connects from your SUB PBA (daughter board) to your main PBA board. another problem which I think might apply to you if you changed the frame to a new one is that the frame has RF(radio frequency) issues. you would have to replace the frame. when getting a new frame, it is best to get a refurbished OEM frame than getting a copy one as you won’t be able to find OEM brand new frame in the market.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Armen Orbelyan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 162
