주요 콘텐츠로 건너뛰기
아우터는 쌀쌀한 날에는 몸을 따뜻하게 해 주고 축축한 날에는 젖지 않게 해줍니다. 수선 난이도는 간단한 꿰매기부터 복잡한 칸막이 수선까지 다양합니다.
Can do you repair a rubber linning of a rain jacket?
The rubber linning of my rain jacket is peeling around the neck and shoulders. Can it be fixed?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
I just ordered (HeatnBond Liquid Vinyl Water Proof and Stain Resistant Gel Coating, 8.68 oz) from Amazon and will try this on an old North Face rain jacket, has anyone tried this to "re-rubberize" the inside of a rain jacket?
댓글 달기
답변 1개
Check first to see if the product is covered under a warranty. High performance products often are.
TLDR Probably not cost effective to repair otherwise.
The water shedding, “breathable“ membrane starts to de-laminate due to a combination of UV exposure and evaporated body oils. You might be able to remove the membrane but then restore with what exactly? Assuming it will effectively bond with the substrate, Spray on exterior silicone sealants can be utilized with varying success.
In either case, you will still not obtain the original performance, breathability, so you won't be as
comfortable.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Caroline 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 21
전체 시간: 1,250
