주요 콘텐츠로 건너뛰기
모델 A1225 / Early 2009 / 2.66, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
164 질문 전체 보기
I want to know Bluetooth module pinout for iMac 9,1
I can’t seem to find the pinout for my Bluetooth module (BCM92046MD), as per photo:
In particular I need to know which pins are for D- and D+
Background:
In an attempt to activate Handoff/Continuity, I’ve installed a BCM94331CD wifi-bluetooth combo card.
Wifi works fine, but bluetooth is unrecognised by System Profiler. That suggests to me that I need to connect to D-/D+ cables to my my wifi card adapter. I soldered up a dongle to what I thought were the D-/D+ lines on the old bluetooth cable socket. But when I tried to boot, I only got a chime, a white screen, and no further. So, I may have got the pins mixed up.
Any help would be greatly appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You really need the combo card Broadcom BCM94360CD. Activating the Bluetooth on it. Take the current BT card out.
This is what I used iMac 2009, iMac 2010 and iMac 2011 – Apple Broadcom BCM94360CD – 802.11 a/b/g/n/ac with Bluetooth 4.0 kit
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks Dan, but my understanding is that BCM94331CD is a combo card (same as BMC94360CD, but with Wireless-N).
Anyway, I think I found the pinouts here:
http://homokozo.czo.hu/iMac2011mod/iMac2...
Yes, the board you have is the older one. I was not able to get it to work. But the real issue is the Bluetooth services on the combo board need to be used not using the older BT board. The kit is what you need as it offers the needed extension cables and the USB power & data connection the BT services uses.
댓글 달기
귀하의 답변을 추가하세요
Andrew Vines 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 855
