주요 콘텐츠로 건너뛰기
The Iconia One 10 was released in October 2016 by Acer. With a 10-inch screen, it has dual-band wifi, 24GB of storage, and a long battery life. Model number: B3-A30
Home button getting in the way of Netflix buttons
Hello. I think Netflix must have recently updated their app and moved some buttons around because now some of the menu buttons are at the bottom of the screen. The problem is that my tablet is permanently displaying the home and back buttons in the app so I can’t get to the Netflix menu buttons. For example I try to press Downloads but the home button is over the top so it just clears the app. I tried swiping down to see if it would remove the tablet buttons but they don't clear and I can’t get anywhere on the Netflix app. Any ideas? Is there a way to rollback the app to a previous version or to change a setting so that the home button isn’t permanently in the way?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Allow you tablet to rotate the screen. If the home button is in the way when you are holding your tablet horizontal, rotate it 90 degrees so that the screen is vertical. This should allow you to access these buttons on the Netflix app. You may have to go into your settings to allow for the screen to rotate.
https://sg.answers.acer.com/app/answers/...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 585
