주요 콘텐츠로 건너뛰기
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
My MacBook air is shutting down randomly
Hi my macbook air 2017 model shutting down randomly. Then I tried to restore my macbook air through time machine backup. After starting my laptop, after every 5 minutes my laptop gets turn off. I am from countryside in nepal and its very hard to visit apple support center from here. What can be the solution??
please guide me
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
I have checked the battery cycle and it is ok the battery life no is 92
Okay that's good! A lower count is better. It may be a logic board or overheating issue, or even the hard drive. It might need opened to determine more.
Did you find any solution? I really appreciate your help.
댓글 달기
답변 1개
선택된 해법
Did you notice when it started happening if anything major occurred that could cause this? Let’s try checking the battery cycles by going to the Apple on the top left, Selecting “About This Mac,” click “System Report,” then click “Power.” In the power section near the bottom I believe it gives you a cycle count. If that is high, or if there is a message saying the battery needs replaced, it could be the battery going bad. Also, do you notice if it gets hot at all? It could be an overheating issue, but doesn’t sound as likely if it is shutting off only after 5 minutes.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi, did you find the problem? And how you fixed this issue?
댓글 달기
답변을 추가하세요
Ujwal Koirala 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 4,283
