주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Why won’t my phone turn on?
My iPhone randomly died, it had been through a little bit of trauma, it was thrown against the floor and got a little bit bent. But it worked perfectly fine still. Then suddenly it turned off and it won’t even charge. What’s going on??? Is there any way to fix this? If not is there any way to replace it for free?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Thrown to the floor ? It was very lucky the phone worked at all after that. Further a bent case puts continued pressure on components. Would not be surprised a bigger chip inside got partly lifted from the logic board and developed oxide with time. You may try replacing battery not to let a cheap and easy replacement untried but it may as well be useless. A lab into microsoldering may figure out what the issue is and repair it but it won’t be a cheap fix. Replace it for free ? whom would you exactly expect to do that and why ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Lee Ani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 37
