주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Damage to digitizer cable
Replacing the cables after putting in the new battery, there is this warning at step 20:
When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
What does this damage look like? I hooked everything back together for a test and the phone functions BUT: there is a black patch about where the wi-fi, battery charge is shown, and wide grayish vertical streaks on the screen; the screen is also slightly faded. Did I damage that connector? The screen was fine before.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The connector on the 6s isn't too bad its mainly the plus that is temperamental because the connector is physically longer...
The problem u describe sounds more like a faulty screen. Disconnect and check the connectors though make sure it's not bent and the pins dont look like theyve come away from the flex
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Well what happens sometimes is that the connector becomes a bit concaved.
To fix that you put one finger above and one under and attempt to flatten the connector back very carefully.
If you look at the pins carefully on its side you'll see where the bend is very easily if there is one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Both helpful responses. The screen was fine when I began. I have been back through the procedure several times and the cables all seem to seat correctly and the phone will start up but the vertical striations and black patch covering the battery, w-fi status are still there. I don't think I damaged the screen but who knows.
댓글 달기
귀하의 답변을 추가하세요
dbh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 146
