주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
LCD Screen Refurbishing Problem #1
I just got into refurbishing screens a month ago. After seperating my 6s glass from the lcd I tested the lcd by connecting and it functioned well. I was having trouble finding an OCA remover so I began reading threads and heard WD40 and goof off worked well. I used a bit of WD40 and goof off ( separately a different intervals) but was worried it was too strong so I was careful with how much I used. After the OCA came off and lcd was clean, I plugged in the screen and there is now what appears to be some wavy ridges when the apple sign pops up towards the top and sides of the screen . Why could that be? Did I apply too much pressure? Did what I used get into the back light or mess up the lcd itself? Is it because I need to remove and put in a new polarizer? I noticed these ridges or wave like things are only visible through white light( first picture) other then that the lcd quality is perfect when displaying colors (2nd and 3rd pictures). I personally don’t mind them but a customer might. I’ve since bought 8333 OCA remover and was gonna use but I wanted to ask the forum before I tried removing OCA again and potentially ruin another good lcd.
thanks!
best,
mrjrizo
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Usually the wavy lines on white background are from too much heat when separating glass, try 65-70deg.
Try the 8333 but don't just squirt loads on, apply it onto a dust free cloth placed on the LCD so to minimise it getting behind the backlight.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@bobcat1981 thank you! Is there anyway to save that particular screen from these wavy lines and continue the refurbishing process on? im going to try 65-70 degrees from now on, at first maybe i thought that those wavy lines were because of the pressure i was putting on it when i was cleaning the OCA. I hope theres a way i can save it I'd hate to throw this LCD away! Is it worth it finishing the refurb process on this particular lcd? can i save it and get rid of the wavy lines? if so how?
댓글 달기
귀하의 답변을 추가하세요
Javi Rizo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 87
