주요 콘텐츠로 건너뛰기
1.6 또는 1.8 GHz dual-core 프로세서, 2 GB 또는 4 GB SDRAM, 64 GB 또는 128 GB SSD
192 질문 전체 보기
Unglue MacBook Air battery cells?
I have a MacBook Air 11-inch from 2011. A few years ago the battery started swelling and I bought a cheap used replacement on eBay.
The replacement isn’t so great since the battery life is poor and the plastic screw holes are damaged. It fits in fine for now but I’d prefer something better since the computer is now getting more use than before.
I still have the old battery and it’s clear that only half (3) of the (6) cells are swollen/bulging. The others (3) appear normal. Is there a safe way to detach the swollen cells? Can the MacBook Air run with only half the cells? Can I transplant cells between battery enclosures? I don’t want to attempt this if there’s a legitimate fire risk.
Any thoughts appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Sorry your system will not work on half the cells. You are more likely to hurt your self given the batteries condition.
Dispose of the battery properly! Don’t mess with it!
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
As Nike says, “Just do it”
MacBook Air 11" Mid 2011 Battery Replacement
MacBook Air 11" (Mid 2011-Early 2015) Battery
MacBook Air 11" (Mid 2011-Early 2015) Battery 이미지
상품
$59.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Dan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 147
