주요 콘텐츠로 건너뛰기
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
42 질문 전체 보기
My left stick goes up and down, but not left and right.
My left stick goes up and down but not left and right when plugged into the switch adapter. It only reads up and down. When I plugged the controller into the Wii the controller read as holding down right the whole time. Reset controller w/ x,y, and start, but when I let go of the buttons it just scrolled again.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
2 댓글:
Have you tried to take it apart and clean the contacts yet?
I took it apart, cleaned everything plastic, didn't risk cleaning the board with my current knowledge.
댓글 달기
답변 1개
Use some glass cleaner to clean the contacts on the board with a soft cloth. Also clean where the joystick contacts the board. It sounds like there could be something on the board that is causing the controller to signal moving to the right.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Discarded Couch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 19
전체 시간: 1,325
